The idea of a project is to have fun. Don't worry about time lines. Figure out what you want to build. Move back and forth to different areas, motor, body, brackets, ect. If the part doesn't meet your expectations, redo or pitch it. Eventually the big picture will come together. You'll forget about the time spent. But you won't forget something you let slip instead of doing righht.
Doug
If it isn't fun, it's not worth doing... Sometimes a deadline helps. It might not get finished, but the project will for sure get pushed forward. Without a deadline, it's easy to say "I'll get to it later". One of the biggest things is you have to have the finished project pictured in your head. Having the vision helps you get there.
