My 493 10.5-1, 590 mopar cam, edel rpm heads 600hp
Upgraded to indy ez and solid roller made around 720hp
426 6.1 base. Eagle heads. 10.5-1, .600 lift hyd cam 620ish hp
That upgrade on the BB cost alot of money. I put aluminum caps in the motor when I upgraded because I got "nervous". Roller cam and everything that goes with it. Very spendy. Going over that 600 mark seems to get much more expensive
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
