Just my opinion but it looks maybe a 10% better package to a comparable older engine up to a point. Mainly cubic inches, once over 450 cubes no matter how good the heads flow, once over that number the big cubes should be faster, easier to build, and at a lower rpm. Now if they make a block that can go 500 ci and over (can't see that happening with the bore spacing) no contest.
