I didn't like the BBC option because the lower hose is on the wrong side, I would have needed a new radiator to go along with it. I've also had bad luck with water pumps and motor plates leaking, so this seemed like a good alternative.
$400 water pump and $300 worth of -16 fittings and lines.
As the kids like to say YOLO.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
