Originally Posted By sixpackgut
That car has a steel hood?
It did, will be ordering a glass hood for it once I decide what I want.
Originally Posted By onig
Where did you get the wiper motor block off plate?
What is the width of the engine plate?
Did you trim the width at all or is that how it came?
Bought the wiper block off plate from a website that no longer exists.
Motor plate is as delivered from AEI, It could stand to be about an inch wider and taller. The Milodon pan will hit the K frame if you set it on the rails.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
