I added some ears to the 1/2 inch motor plate. Tied them in to the lower frame rail and upper frame rail. I will run some jumpers back to the lower cage structure, then tie in the top back to the dash bar. I will run a bar inside tieing the top together just inside the fire wall (so I can still access the top trany bolts)
