Here's my suggestion for new Hotchkis parts- make a correct wheel rate front sway bar for the 73+ A body K member. I doubt the market is large enough to warrant a full R&D on a 73-76 k member, but at the very least you can use the R&D from the early K member and get the wheel rate right on the 73-76 K.
Fair enough.
As to the 73-76 A bodies, what is the difference you are referring to? Just overall vehicle weight, or something I'm missing? I wasn't aware of any difference other than engine mounting style.
