Quote: Since I don't think a broad market solution can be found, but best as possible universal "monte Carlo" brace. The market aspect would be limited, because it would soon be copied by many.
A more refined higher performing bolt on oem style swaybar end link system.
I would like to see if workable, an adapter sleeve for OEM spindles to allow for a larger bearing package, hopefully allowing for a larger then the typical Wilwood alum hub, still in Alum, and maintaining at least the 5x4.5" BC as one option.
I Like the sway bar end links and the Monte Carlo bar...Put in the Monte Carlo bar with rivnuts or a nut plate and connect all 4 sides of the engine compartment together to improve overall rigidity. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
I didn't do 4 years and 9 months of Graduate School to be called Mister!
