humm where do I start? I don't hate the Eddy/Carter carbs, however if the car goes to the track I wouldn't use one. I would use another Eddy if I wanted a driver as they do tend to be better suited for a daily...or cruiser car. But then again I guess one could always use a small vacuum holley. If I shelld out the cash for a Hemi and it only made 393hp I'd be depressed. Tey an 800 thunder or 850DP and you see what that thing can do. My lame 6-pack is still pulling hard at the stripe (heavy car just like yours). The eddy 750's seem to run out of steam at 3/4 track. (unless you are using 2) And the comment on air bleeds has been missunderstood. I have never monkied with air bleeds..is that better for you? Even when I went w/ a proform main body. When you can take an out of the box Eddy 750 and use the basic strip kit drop it on a mild (425-450ish HP) BB and beat a 750DP let me know. last word, read some posts. I'm not the only one that feels this way.
