Yes I am going to try the ATF and readjust the clutches. I can't exactly test anything right now. The current outside temp in Minnesota is -14 degrees. Test drives would be though even If the ground was not covered in salt........no salt ever.... I think I might go with the D60 3.54 change and hemi 4 speed. Even if I do that I will swap fluid first and adjust clutches prior to removal to satisfy my curiosity and so I know the A833 OD is solid before I sell it to someone. I will post my findings. Thanks
