Quote: McLeod can re-hub your discs for the 18 spline. Put your 18 spline back in, change the D60 to 3.54 and run a 28-9" tall tire.
I'm sure a 4.10 with a 3.09 low gear trans 1st gear doesn't last long.
I would listen to this guy! He knows his stuff. Or call him. He can put you where you need to be .
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
