Like John has mentioned
Just to add
With the three piece adjustable kickdown linkage usually found on the 71 cars , that rod that attaches on the tranny came in different lengths depending on the motor - Also the bracket itself that attaches to the intake manifold was different between motors
So another words you can mismatch many pieces with the three piece setup like pictured because of all the variations between motors
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
