My .030 over 440 makes 643HP at 6300RPMs and 592lbs of torque at 4400RPMs.
Can I see the details of your combination? And do you have any ET & MPH results from track to go along with it? Thanks!
Sure here is the combo.
.030 over 440
bushed lifter bores
11.1 CR
Comp solid roller cam [Email]248-254@.050[/Email], .622-.612 with 1.6 rockers
all the bearings coated.
MW ported SR heads
Ported indy DP intake, Pro-Systems carb
Lots of engine coatings- inside and out outside of the intake,tops of the pistons, sides of pistons, intake ports exhaust ports.
Do all those coating help make HP? who knows, the motor does rev quick thow.
Bud Yancer did the machine work and Sheldon Gecker bolted it together.
No I have not had it to the track, as I said it keeps throwing the alternator belts. I need to come up with some kind of idler pulley for the belts.
Also the pistons are five out of the hole with a .039 head gasket.
