Ok
Worked on the Carb today I pulled the carb off. A freind let me borrow a good card today. When I pulled mine off the top of the gasket was gas soaked. So I had another gasket to put on. Put my freinds on really didn't perform any better than mine This was a holley 750 double pumper way to much carb for my car. So I pulled it off and there was no gas on the gasket put mine back using same gasket Adjusted the floats and the Idle air screws actually ran pretty good. No hesitation at all My int at 18 vac 14 mechanical advance or total was around 40 stil not to good Hope its better with new carb from FPO.
