Quote: I did change the springs Ran it at 18 seem very rough running was smooter than that before. I did put 1 OE back in the other was in pretty bad shape. So i put a new light one in probably not the right thing
it may have had less initial as the 18 might have including it being into the slots back when it ran smooth so it might be now wanting less actual initial than the erroneous 18 showing b 4. You can mix/match springs no prob & if (1) light MP spring & (1) OE light spring would from my chart start at no less than 850 rpm
