Well first thing you need to do is get a double pumper and get rid of that vacuum secondary carb. DP's are much easier to tune and preform way better. You simply aren't getting the fuel needed to make it run. I'd do a 750 dp right out of the box and see what you got. Tuning will be necessary.
