Ok on the slots there's a R15. When i open my weights the pins go all the way to the end towards the weight.There's no room at end of slot. Pin goes all the way. Weight's are almost touching inside of case.The slot bar does not rotate stays straight.Really not alot of room in there. But for sure there's no room at end of slot. Kevin
