Quote: Your opinion do you think i should change the cam and if you do what type. I woulld have to pull the engine someone told me one of my cam bearings is alittle crooked lowering my oil pressure. Kevin
Is this the same "someone" that told you not to degree the cam?
In theory, there is no difference between theory and practice. In practice, there is.
