Ok Set int timing no vacuum plugged 18 on damper zero on timing light.
Turned up engine to 3500 rpm and turned dial on timing light. To get the zero at tdc the light showed 23 total Really have no clue at this point. Are the mechanical weights in thge dist opening not sure. any idea kevin
