Quote: someone told me one of my cam bearings is alittle crooked lowering my oil pressure. Kevin
Actually that'd raise your psi as it'd reduce the orifice(s) feeding the heads (rockers). I'd work w what you have now for now & get it as good as you can as opposed to extensive internal parts swapping which the cam/lifters/breakin would b
