My cam is similar but with a couple differences.. mine is 105 lsa installed at 105(didnt want the added torque with advancing it to increase the stall point) the lift is the same but I have a few more degrees on the exhaust side... same on the intake... with basically the same compression.... I know your gonna have more torque due to the stroke over my set up
similar to my cam too 254/262@050 .200 179 /184 cam lift 430/420 on 107 with 11.2 comp pulls like train with the indys , people over cam there engines some times these size cams are great street/strip cam well done with the build with great info and graphs ,you will love going down the strip with that combo
