Quote: 4+ inch stuff I typically won't spray or boost, side loading increases with cylinder pressure regardless of stroke or rod ratio so (obviously IMO) if you have long stroke short rod combo it's a little harder on the block with your normal cylinder pressure.
I like the 4+ inch motors when I'm looking for a true Big block 'behind the wheel' experience and where you run good (but not necessarliy "great") heads that limit the RPM (and more importantly piston speed) to a moderate (5800-6200 ish) range.
If you're boosting or spraying, I keep the stroke shorter and the rods longer, if I'm looking for a dual/purpose motor with Longevity. That said the +4 stuff works very very well on the street when set up for the purposes I described above. Torque motors are sweet on the street!
Question: What do you consider street longevity? At what point would you consider a freshen up on a long stroke NA small block Mopar? I think that's what a lot of people want to know with these new big stroke cranks out nowadays.
