Quote: Any cooling system changes needed? Can you go to a smaller radiator ie like running straight methanol?
I didnt... I keep the whole cooling system the same, I just leave the fan and pump off a little longer then turn on the pump and wait till the temp is up to 160 for the burnout... after the burnout I turn the fan on for the pass... at the end of the pass I'm at 180
