Well if mixing isn't easy what can I do to just run the car on E-85? The only thing is there is only one station within 40miles that sells E-85 so I either need to fill a 55 gallon drum or be very careful how far I drive.
Don't do it. There is no E85 stations here ether but I choose to buy barrels of E98 and mix my own.Once that is gone I will buy E85 from a station 45 miles away by the barrel.But I only use mabe 10 to 15 gals. a week.If I had a street car NO WAY would I consider E85 without a station close by.But if you are a hard head and you like to buck the normal E85 will give you more performance and runs cooler and you can run alot more compression on the street.
If the MODS did their job I would not be hitting the notify MOD button. LOL
