Is the E85 something you could buy a drum of for the season,,,check the blend with a tester like Mike mentioned,,,get your jetting dialed in for that particular blend,,,and forget about it ?
Would if require messing with the jetting ALL the time,,,or just when you get a new "batch" of fuel .... and have to figure out what the blend is.........?
