Quote: The houseing passage is much smaller then hole in block. I can't even get a finger in the port on houseing
ok, that might be a problem...can you open it up at all to be at least as big as the holes in the block?
my housing from 440 source works fine...I had to replace the pump though, but only because my custom serp set-up has the pump spinning backards, so I needed a pump with straight vanes that would work when spun backwards.
