The passages on the 440 Source housing are smaller than a stock housing but they are big enough. The problem is the pump, it flows well at high rpm but not enough at low rpm.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
