New 160 stat. Brand new 3 row rad. 18 inch clutch fan with shroud. Fan properly spaced. Carb adjusted a tad rich. timing set. Car isn't puking anti freeze but gauge is reading higher then it did. The 440 sorce houseing has the temp sensor on drivers side near head. My stock houseing had the temp sensor behind the nipple on passenger side. Am i getting a higher reading from that spot?
