Yes that is the distributer I used. If I had a small block I would have modified a ford dist. The throttle body is this one http://www.summitracing.com/parts/HLY-112-510/ 80mm. The MAF sensor is a used pro flow 80mm calibrated for the used 30lb injectors both from Ebay. I wont be tuning for a while still have wiring to do. and then final body work and paint. But I will keep you posted when the time comes.
