Re: I give up, 440's just run HOT
[Re: 69chargeryeehaa]
#66179
06/04/08 09:07 AM
06/04/08 09:07 AM
Posts: 4,961 WI
Dcuda69
WI
timing is 15 initial, 20 deg mech adv, total 35 plus vac adv 14 (ported port)
yes it cools down when you revv it in N,
Mr Gasket highflow stat.
50/50 mix.
So i've been reading posts i searched for on dodge charger board while moparts was down, and found this one: web page
at the end on page 2, he says it was the fuel pump in the end. Now hear me out, last night my car actually died on me at about 190, i started it back up held the rpms at 2000 for a min and drove off, after several attempts of this i was off, and drove 20 mi home with no problems (but always moving, temps were at 180 moving, and creeping up at lights, but they were all short), but i have been noticing lately it's not running that good idle when hot as it used to. I don't know why it starts running like crap when it's hot, but i'm putting 2 and 2 together here and thinking that the fuel pump is getting hot, and failing, at idle causing a lean condition which = HEAT, and ultimately my problem. I'm sure my combo, parts used are good in the cooling system, and this just doesn't make cents. Whatcha think? ummm?
I don't want to throw parts at this like alum rad, fan, i should be able to cool with totally stock stuff, which by the way is all NEW, new rad, belts, water pump, hoses, stat, rad cap, ect....i'm done with the cooling system, it's all new stock stuff it should be enough to cool my stock motor no?
I think you're on to something. I've been watching this thread and it contains lots of good cooling system tips.However I don't feel 200 is too hot. My car will creep up to 200-210 in traffic on a hot day,but it never affects how it runs. I would look long and hard at fuel and fuel delivery,from the tank to the carb. Maybe borrow a different carb to try? If your car creeps up to 220-230 or higher,forget everything I said and go back to your cooling system. But I wouldn't worry about 200 and it should't cause running issues! Good luck
Entire Thread
69chargeryeehaa
05/30/08 03:24 PM
bobby66
05/30/08 03:33 PM
69chargeryeehaa
05/30/08 03:59 PM
68LAR
05/30/08 04:42 PM
69chargeryeehaa
05/30/08 05:07 PM
69chargeryeehaa
05/30/08 04:25 PM
JohnRR
05/30/08 04:33 PM
69dart
05/30/08 04:39 PM
69chargeryeehaa
05/30/08 05:03 PM
68LAR
05/30/08 05:12 PM
69chargeryeehaa
05/30/08 05:19 PM
68LAR
05/30/08 05:32 PM
HotRodDave
05/30/08 05:50 PM
DaytonaTurbo
05/30/08 06:02 PM
ademon
05/30/08 06:23 PM
05/30/08 06:24 PM
69chargeryeehaa
05/30/08 06:28 PM
p d'ro
05/30/08 07:18 PM
BobR
05/30/08 08:12 PM
VT_Dart
05/30/08 08:23 PM
69chargeryeehaa
05/30/08 08:55 PM
IronWolf
05/31/08 02:23 AM
472 R/T SE
06/05/08 10:17 PM
69chargeryeehaa
06/06/08 02:16 PM
B5 GTX
05/30/08 07:27 PM
Mopar73340
05/30/08 08:03 PM
JohnRR
05/30/08 08:12 PM
Exit1965
05/30/08 11:25 PM
Ronnman
05/31/08 12:09 AM
ChinooK440
05/31/08 12:22 AM
kenworth_goose
05/31/08 01:00 AM
BobR
05/31/08 03:59 AM
Exit1965
05/31/08 04:07 AM
BobR
05/31/08 04:14 AM
pro451bee
05/31/08 07:48 PM
69chargeryeehaa
06/02/08 11:04 PM
ahy
06/02/08 11:06 PM
69chargeryeehaa
06/03/08 01:34 AM
W5Duster436
06/05/08 04:56 PM
340Scamp
06/03/08 01:47 AM
06/03/08 02:10 AM
Challenger 1
05/30/08 08:17 PM
DaytonaTurbo
05/30/08 08:26 PM
HotRodDave
05/30/08 08:47 PM
05/30/08 08:47 PM
p d'ro
05/30/08 08:53 PM
DaytonaTurbo
05/30/08 09:01 PM
B5 GTX
05/30/08 09:08 PM
05/30/08 09:51 PM
ToddP
05/31/08 04:35 AM
HotRodDave
05/31/08 01:05 PM
A38s!
05/31/08 04:58 PM
captaindodge
05/30/08 05:24 PM
05/30/08 05:31 PM
79powerwagon
05/30/08 05:35 PM
MoparforLife
05/30/08 03:37 PM
69chargeryeehaa
05/30/08 03:58 PM
HotRodDave
05/30/08 04:05 PM
p d'ro
05/30/08 04:20 PM
Paul_Fancsali
05/30/08 04:27 PM
basketcase
05/31/08 03:37 AM
GODSCOUNTRY340
05/30/08 03:39 PM
05/30/08 03:56 PM
69chargeryeehaa
05/30/08 04:03 PM
captaindodge
05/30/08 04:34 PM
69chargeryeehaa
05/30/08 04:00 PM
JohnRR
05/30/08 04:05 PM
JohnRR
05/30/08 04:35 PM
69chargeryeehaa
05/30/08 05:02 PM
68LAR
05/30/08 05:06 PM
69chargeryeehaa
05/30/08 05:09 PM
dwbiggs
05/30/08 08:42 PM
DusterKrazy
05/30/08 09:04 PM
05/30/08 09:12 PM
Sixpak
05/30/08 09:15 PM
05/30/08 09:19 PM
cyphre666
05/30/08 04:23 PM
RapidRobert
05/30/08 09:28 PM
Exit1965
05/30/08 09:48 PM
ngpSatellite
05/31/08 06:37 PM
torkrules
05/31/08 01:06 AM
Sinitro
05/31/08 05:37 PM
06/03/08 02:19 AM
440trk
06/03/08 05:48 AM
Exit1965
06/04/08 12:50 AM
69chargeryeehaa
06/04/08 02:17 AM
06/04/08 03:49 AM
BobR
06/04/08 04:48 PM
69chargeryeehaa
06/05/08 02:59 PM
Old_Moparz
06/05/08 03:39 PM
69chargeryeehaa
06/05/08 03:42 PM
B5 Bee
06/05/08 04:30 PM
69chargeryeehaa
06/05/08 04:48 PM
RapidRobert
06/05/08 04:59 PM
69chargeryeehaa
06/05/08 07:29 PM
RapidRobert
06/05/08 08:22 PM
69chargeryeehaa
06/05/08 08:29 PM
RapidRobert
06/05/08 08:41 PM
HotRodDave
06/05/08 09:00 PM
69chargeryeehaa
06/05/08 09:11 PM
JohnRR
06/05/08 09:39 PM
ChinooK440
06/05/08 11:29 PM
06/06/08 04:28 AM
Joshs68
06/06/08 05:11 AM
69chargeryeehaa
06/06/08 02:22 PM
black64
06/06/08 06:24 PM
69chargeryeehaa
06/06/08 06:34 PM
JohnRR
06/06/08 06:35 PM
69chargeryeehaa
06/06/08 06:40 PM
GODSCOUNTRY340
06/06/08 08:47 PM
06/06/08 08:58 PM
340Scamp
06/07/08 12:43 AM
06/07/08 12:48 AM
black64
06/07/08 02:00 AM
Cudalord
06/07/08 02:29 AM
Pool Fixer
06/07/08 03:55 AM
BobR
06/07/08 04:56 AM
Neil
06/07/08 05:11 AM
06/07/08 01:53 PM
69chargeryeehaa
06/08/08 05:10 PM
black64
06/09/08 12:36 AM
p d'ro
06/10/08 08:11 PM
69chargeryeehaa
06/10/08 08:21 PM
69chargeryeehaa
06/06/08 02:20 PM
06/04/08 09:45 AM
Dcuda69
06/04/08 01:07 PM
71383beep
06/04/08 02:19 PM
TrueTripleX
06/05/08 05:34 PM
ademon
06/05/08 06:39 PM
69chargeryeehaa
06/05/08 07:25 PM
