it might actually be your old line breaking up inside. depending on how old it is. it could be the new fuel pump. it could be crud hung up in some part of the line that broke loose when you put it back in place. it could also be something that was still inside the carb in the passage where it turns down to hit the needle. just clean it up again and see what you see.
