Wes, I met a racer in Florida that raved about Norwalk Speedway in Ohio, and Summit motorsports park is real close. Plus you would be centralized somewhat. Minnesota has BIR, in the middle of the state. If you locate close to the south east corner of Minnesota, you are not far from a number of tracks. Rockfalls raceway in Wisconsin, Cedarfalls in Iowa, Tri State, Iowa, Eddyville is in South East Iowa, Humboldt, Iowa. The area in southeast Minnesota is very beautiful rolling hills of the Mississippi River Valley. And Mayo Clinic is in Rochester. If you locate in Southern Minnesota, I am at most 130 miles away.
Great info, Greg. Thank you. I've been to Norwalk, and its a nice facility. I've also been to other Ohio area tracks.
