Here are two pics of the inside of the Morels. In the second pic you can see where the machined channel intersects the oil hole in the body. In the first pic you can see the channel doesn't meet the oil hole.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
