Originally Posted by TJP
Originally Posted by 73cuda340
The last seal that I put in was one of the fast fish one piece seals and retainer setups. I've only ran the car for about 10 minutes and it hasn't leaked. Just hoping to find out the cause so that this one doesn't start leaking.
When did you install the new seal and retainer ???
You changed two items at the same time so at this time there is no way to know which may have been at fault.
The most recent time I changed it, I swapped in a new retainer with the one piece seal, since I bought it as a kit. Every other time I changed just the seal, or the engine builder did, it leaked.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
