The "data pack" allows them to give you all the data and a wyndyn viewer in a exe file you can install on your computer. At the very least they can export each run to a CVS file so you can put all the data into a spread sheet.
you guys are probably right about the "water out" on a 901. My dyno is a SF powermark and the water out is from the brake and engine temp is from the cooling tower.
Joe
Without Data, you’re just another guy with an opinion.
