That does seem correct, it has a full 3 1/2 exhaust, air filter, clutch fan, it was dead hooking,
1.75 60ft, we did a converter change, installed electric fans, our track will open back up at the end of this month, he said to me WTH your heavy a$$ street car Charger MPH is about the same as this car. [/quote]
That ET with those 60 ft. times are no where near the best on the 60 ft. times
I think it should run mid to high 1.40 to low 1.50 60 ft. times at 10.80 in the 1/4 mile
Thinking back over my racing at the track, I've seen a gain of .15 ET and .4 MPH in the 1/4 mile when I pick the 60 ft. times up by .10
It may be the converter holding you back now
What brand and size is it?
