My thoughts, and I am no engine scientist lol. I think a carb vs THROTTLE BODY EFI the carb is better, fuel flows through it 100% of the time there is no pulsing of injectors to interrupt the stream of fuel.
I think IF port injection doesn't atomize better it at least allows better control of where the mixture goes, and with some EFI systems you can adjust that per cylinder.
