Are there any ideas as to what would cause the leak only to happen while the motor is being reved? If the seal was damaged and or installed incorrectly, shouldn't it leak at all times? Is it possible that it's a crankcase pressure issue that is building up pressure during higher rpm's?
Leaking head gasket might do it - might as well check & compare cylinder compression
