Ok, I'm finally in the middle of trying to install the new rear main seal kit. The two halves actually slide in very easy with the crank still in the motor and the mains are still tight, which kind of worries me. The other problem that I'm having is with the side seals. Is there any trick to get these to stay in? Every time I go to slide the retainer into the block it pushes the seals right out. I've tried using a high tack gasket sealer on them and letting them set up first to try and help hold them, but they still just push right out. Am I better off just eliminating them and using a gasket maker in their place?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
