Originally Posted By Thumperdart
Originally Posted By fast68plymouth
I'm sure that would help with the part throttle.
Did you guys mess w/the emulsion cos you can change the mixture quite easily in the range needed buy the location and sizes.........
Not enough time to "go deep" on any one carb with multiple items on the test checklist.
I'm going to take a s.w.a.g. that a day on the dyno spent on tuning ONE carb is probably enough to get a basic carb sorted out, if the original tune isn't close.
