Don't monitor it. I do run race gas (110) and spray ( Snow system ).
Gotcha, was wondering how things do with the hot air setup you have. Makes plumbing easy tho
Actually, I don't use the intake system in the pic. I run my filter directly on the intake horn of the compressor. Without inner fender panels, I have enough air circulation under the hood that it doesn't make any difference where I pick up intake air.
