Here's a shot of the driverside front fender. You can also see some "kittyhair" filler on the top of the fender. I had some other rust repaired when I first started this project. For some reason they slapped that on instead of skimming it. I had my new guy sand it down to make sure something wasn't hiding there. Turns out it was fine. My goal is to have minimal filler on the car.
You can see some "jagged" rust where the metal overlaps at the fender mounting flange. This was not repaired before and I had the new guy fix it. This is the before shot.
