[quote=birdtracker]Motor is 14.8-1 and I run it on C-16. It had 235 passes on it when it was torn down and new aluminum rods installed. So tomorrow night its either leakdown test or cam timing. I am now suprised it ran with that low of compression Birdtracker [/quote
235 passes, what did it used to run in the beginning? Was is quicker, actual 119 1/8? That low compression it appears the cam is in way late. Doug
