Motor is 14.8-1 and I run it on C-16. It had 235 passes on it when it was torn down and new aluminum rods installed. So tomorrow night its either leakdown test or cam timing. I am now suprised it ran with that low of compression Birdtracker
Just remembered reading this...235 runs then new rods. Where they the same size? Anything else changed? What where the times before these changes? Did you run this engine before the changes? Did you just buy it ?
