For a comparison......a friends S/G Cuda from about 10-12 years ago. 2700lbs, 4.88's, 15x33's, glide, 1.76 low, 451 low deck, std port stage 6 heads, tg4500 intake, 1200 carb, 2 1/8 x 4 headers, UD 280/685 roller....... Motor dynoed 650hp. Went 9.30's at 143. My recollection is that the 60' times were in the high 1.20's.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
