I thought it should be around 180. The rings are Childs and Albert Moly file fit. I did them. I did look around my garage to see if I forgot!!! So on leakdowns that I have done it takes the piston to be at the top to have both valves closed. I may have to ensure valves are closed and piston maybe not all the way up? Birdtracker
