valve lash is .022 cold. Both convertors flash what they should.I also had the trans out this spring and had it gone thru at a trans shop. New transmission lines and cooler. Birdtracker
So I ASSume it around a .028 hot cam? I run mine at .014 cold and end up around .020........this is about WAY more than lash cos something is amiss here big time...........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
