Good info Mike.
I'll check, but I think 150% is about what my paint man used to get the fine '320 grit' texture. Tom Quad from Moparts (see attached) was suggesting 125% in his application procedure. Thinning is key in this ongoing texture and sheen debate.
Also attached is a variation on that TSB with instructions to 'shake well' and 'use DP-90 primer if desired'.
Link to Slideshow...turn the music up. http://albums.phanfare.com/isolated/F39VvCq5/1/1491997 ...So when does government's A12 welfare start?..
