Once above the torque peak the penalties for low compression diminish a bunch I am sure. At peak torque reversion should be gone, so the power loss could be figured from a "compression change only" stand point, I would think. A 279/289 cam may be shorter on working duration than it first appears, if it is an older lobe type with big lash.
Greg, Jason only uses CompCams and they grind what HE wants em to............
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
