Hey Mikey I may have missed it but do you care to share the motor internals
Sorry for not getting back to you. Been busy but has eagle crank,Hbeam rods, wyseco pistons, Indy 295 EZ heads max wedge ported by Indy. Compression 11.2 cam spec is in earlier post,
block is stock 230 low deck 400 zero decked. 469.2 inch
has isky red zone lifters slight offset. bushed lifter galleys.
Harland sharp rockers 1.6 Manton pushrods, total seal rings.
Milodon external oil system. Jason Pettis overhauled what I had and did his magic with cam, balancing, & valve job and Dyno.
I am pretty happy with it so far, just need to make it hook better now!
